korting ks53211bw error e1 ⇐ Discount
Автор темыsk80
- My dishwasher: korting
Hello. After turning on the program, the drain pump is activated, after which the valve opens and water begins to flow in. After 2 minutes, error e1. water pressure of about 3 kg. the pan is dry, i.e. The pan sensor is open. I found a filling unit - there is an impeller in it that is spinning. 5 volts come to the impeller. but what comes out of the turbine is some uncertain 0.2-2.6V. why are they unsure - because the voltage jumps quickly in this range. Could there be a problem with this flow sensor, please tell me.
- Участник
Re: korting ks53211bw error e1
Good afternoon There is a possibility that this error and interruption of the cycle occurs due to slag elements getting into the receiving mesh of the aquastop inlet hose and, possibly, the drain is clogged.
If this is the case, then the repair method described here will help: The dishwasher does not clean well, does not heat the water, and does not complete the cycle. Error "E". Repair methods
The aquastop mesh is clean. And the drain hose has nothing to do with it - after all, the error appears when drawing water, i.e. hmmm doesn’t see this set of water. I increased the pressure on the cold water reducer to 6 kg. - no error. I’m thinking what to do next. By the way, the voltage on the aqua sensor has become 0.4-2.6 volts. It turns out that somewhere something is blocking the flow. But where?
young man
I bought a PMM Korting 45165 on Saturday, December 10, yesterday a plumber came and connected it, after a test run, a squeak appeared a few minutes later and error E1 appeared on the screen. I’m thinking what to do:
1) call a plumber and ask him for a certain “jamb” when he connects the PMM;
2) return the car while the 14-day return period is still valid ".
I am interested in the opinion of experts, what to do or what to pay attention to? Maybe when you turn it on for the first time you need to do everything according to the instructions, i.e. pour in salt and half a liter of water, rinse aid and what else =)?!
Uzzy
I think this would not affect the error in any way. Is the water filling up? Maybe the faucet is simply closed where the PMM connects to the water supply?
It seems like the faucet is open, because... Yes, I could hear the water pouring in, I even opened the door a little and saw that there was some water at the bottom. Those. it draws water, and after a few minutes it displays error E1, after which it drains the water and turns off.
Now, just for fun, I placed the drain hose in the sink and turned on the PMM, it took about 4 minutes to collect water, then drained it into the sink, after which it seemed to collect a little water again and then gave error E1, drained everything again and turned off.
555
Maybe the float is stuck there, as they write in the next topic about Bosch - swing it in different directions.
Good afternoon. How did it all end? Interesting to know, otherwise we also have a problem.
author of the threads, how did you solve the problem? I have the same
bea
Hello everyone!
I have the same problem - E1 on PMM from Korting (we are already 6 years old, I don’t remember the model... 40).
So far I have tried: mashmaster (dot) ru/kody-oshibok-posudomoechnyx-mashin-korting
I wait 15 minutes with the machine unplugged. Water is flowing. I washed the drain mesh. But while the error is repeated... I’m trying to reset the error by disconnecting from the network...
For now, I will tell the owners of korting that there was a problem previously that local repairmen did not overcome (they repaired it and took money twice, but they never solved it). There were no mistakes, the tablet was just smeared and the dishes were unwashed. The repairmen claimed that everything was OK, but they didn’t wash the dishes.
The decision was made to change brains. I changed the board myself - nothing complicated. Everything worked.
2. Turning off the power did not work. The korting machine gives an error E1.
OK. I started the machine again and went to look at the water meter. There is water, but when starting the machine there is no consumption at all, not a drop. At the same time, the machine hums, an error beeps, but something inside is working.
Tomorrow I will look into it further. Perhaps something at the water inlet to the PMM is clogged (although unlikely), or the pump is clogged.
SOLVED!
Replaced the water intake hose in the dishwasher with built-in aquastop (this is the one that has a boss like this at the water intake tap - the valve). The issue price is 2090 rubles. with delivery. The hose (2.0 m filler hose for dishwashers with an Aquastop electrical system) was purchased on the SAMBT website (not an advertisement). The link can be removed by a moderator, but you can also find it in other stores by searching. All the best!
Haildmitry
I also had an E1 error, I decided to replace the reed switch with a working one in the water flow sensor.
In case anyone needs it, the Korting KS 53211BW dishwasher measures the volume of water being filled only using this flow sensor (the reed switch is on a small scarf above the impeller, the impeller behind the left housing cover at the top-back), the pressure switch which is at the bottom right is there only in case of overflow and simply turns on the draining process when the water overflows. The symptoms were as follows: the machine took in water, then immediately drained it, then took it in again and drained it, after which it went into error E1.
- 13025 Views
