Please advise!
The machine has stopped working normally. It turns on, draws water, sits for about 5 minutes, then clicks and opens. tray with a tablet, it flies into the ox. That’s all! costs 10 minutes or more! can on then something happens there, like work. or maybe just stand!! I open it. nothing was washed. table, lies. The water may not be drained. may drain if restarted. The water is not heating up. but there is no washing process!!
can you tell me what and how?
Thank you!
Please advise! The machine has stopped working normally. It turns on, draws water, sits for about 5 minutes, then clicks and opens. tray with a tablet, it flies into the ox. That’s all! costs 10 minutes or more! can on then something happens there, like work. or maybe just stand!! I open it. nothing was washed. table, lies. The water may not be drained. may drain if restarted. The water is not heating up. but there is no washing process!! can you tell me what and how? Thank you!
• Ideal solution for a small kitchen
• Compact and spacious: 6 sets of dishes = ½ capacity of a 60 cm dishwasher, fits a 60 cm oven tray
• Maximum convenience: Quiet operation - 50 dB Possibility of using “3 in 1” tools LED display Timer 1-24 hours
• Savings: Water consumption per cycle – 7 l Noise level – 50 dB Width – 55...
Good people. Tell me, I’ll resuscitate PMM at home. Machine SKS50E12RU/05 ... Works through the program, and upon completion freezes. I think the machine is hanging at the drying stage. I’m not much of a repairman, but apparently there is a problem either in the temperature sensor or in the brain, because throughout the entire hang time the heating element is burning. Tell me where this sensor is...
Electrolux dishwasher. After collecting water, it washes for a couple of minutes, the relay clicks, and the program is reset. Please help me figure it out.
Check the heating element for breakdown. Perhaps the protection is triggered.
