SchaubLorenz SLG SW4400 ⇐ Other manufacturers
Boris Vasylenko
Artem
Re: SchaubLorenz SLG SW4400
This happens, usually after a few washes the salt indicator goes out, you can try resetting the settings or unplugging the plug from the socket for 30 minutes, if the indicator does not turn off at all, then only changing the salt manufacturer will help, salt in tablets is not recommended!
