Cold welding the inside of a dishwasherGeneral questions about dishwashers
Roman Romanych
Post by Roman Romanych »
Comrades! Please give me advice on what to do in this situation. I was putting dirty dishes in the dishwasher and a knife slipped out of my hands and stuck straight with its tip into the metal panel inside the dishwasher, I was glad there was a hole of 1-1.5 mm.
I’m thinking of sealing it with cold welding for steel. Tell me, please, will it be possible to pull this off, will it hold up? Is it safe for the body (are there any harmful secretions? As far as I understand, it contains some kind of polymer and metal filler) I haven’t dealt with cold welding before, or can you recommend another solution? I have already looked at the spare parts - such a panel costs from 7k, I think that this is not advisable. Thank you in advance!
Cold welding the inside of a dishwasher - 9A3E2637-916C-4F5D-A2E3-DF4E25B3B614.jpeg
 Re: Cold welding the inside of a dishwasher
Post by Fulcrum »
You can put a screw with washers and seal it with sealant, it won’t look so bad
