I have a Mastercook ZBI-3646A dishwasher, which began to stop for some time after being turned on, and then all the diodes blink and start beeping. Accordingly, the water does not drain, there is a certain smell. After a few hours you can restart it and it will continue to work again, this continued for about a month. Now it won’t start, it makes clicking noises and then beeps. Where to dig, what could it be?
I’ll add, I pulled out the filter, loading grates, scooped out the water, started it up, it made a squeak and then clicks followed. After that, under the bottom, below the door, I found some kind of plastic chip, indicating up and down, I turned it a little counterclockwise, turned it on, it started working. I worked for 10 minutes and started beeping again, the process stopped.
Mastercook ZBI 3646A ⇐ Other manufacturers
Автор темыAlexey Borisenko
- My dishwasher: Mastercook ZBI 3646A
I want to buy a lower door seal for a Mastercook dishwasher
by nicakani@yahoo.com » » in Other manufacturers - 0 Replies
- 30956 Views
Last post by nicakani@yahoo.com
