The door stopped opening automatically after washing Electrolux ESL 94585 ROElectrolux
areshin71
My dishwasher: Electrolux ESL 94585 RO
Post by areshin71 »
Hello!
The following problem has arisen: after a couple of months of operation, the door no longer opens automatically after washing is completed (the so-called AirDry function). At first I thought that this was a purely software failure (like it was accidentally turned off), but I tried it on different washing programs, and also manually turned on this function by pressing the corresponding button (the function indicator is on). Conclusion: something in the PMM hardware.
The warranty expired literally 10 days ago (I bought it a year ago, and started using it after completing renovations in the apartment).
Please tell me , what can be done and is it really possible to fix the problem yourself?
Thanks in advance to everyone who responded!)
Vlad
 Re: The door stopped opening automatically after washing Electrolux ESL 94585 RO
Post by Vlad »
The same problem, after installing the dishwasher I noticed that the fastening of the door was in the way and it did not open. I fixed this problem and it began to open. But after two months of use, the door stopped opening. I changed various programs, turned this function on and off, but the door does not open.
Noname
Post by Noname »
Same story... Looks like we are from the same defective batch of Electrolysek...
Hunters
Post by Hunters »
I agree, the same problem, the door no longer opens automatically when Air Dry is turned on. Share your experience if anyone has found a solution to the problem.
Hello, we have the same problem. Electrolux
a solution has been found. at least for myself, I solved it this way: turn on the device with the on button, then be sure to press reset, then select the program and close the door. tested in all modes. except ECO and P7 it works, the door opens automatically and the green light is on.
BEAVER to everyone!))))
Vadim
Post by Vadim »
Reset doesn’t help me.
Has anyone contacted Electrolux support? Or to the warranty service?
Same problem. It’s just a disaster
Zaira
Post by Zaira »
I have the same problem and a technician comes and fixes it and the next day it won’t open again, I called twice under warranty, but there’s no point, he says it should be exactly right, that’s the whole problem.
Olga1987@
Post by Olga1987@ »
I still have water left, it doesn’t drain it and doesn’t open the door, the mechanic says that the problem is in the lock, he tinkered with something, the door opened once and stopped again
Same problem with this brand of dishwasher. It was turned off from the network for a day. Once I opened it to 3, the second time, the green light does not light up, it does not open.
anton1028
Post by anton1028 »
Hello. Was anyone able to solve this problem? In the same way, the door does not open, very rarely when it does. While there was a guarantee, Electrolux offered to observe and make sure that the dishes did not touch the body. And when the warranty ends, he offers to send a technician out for money.
Oleg
Post by Oleg »
Remove the front and see if the latch on the door fits into the lock on the machine itself exactly in the center. If, when closing, you see that the door moves slightly to the right or left, then you need to align it and everything will work out.
Try to align the door, it helped us, although I thought there was something wrong with the brain
So that the lock fits exactly at the right time
vgts72
Post by vgts72 »
From the first day it will sometimes open or not. EDA917102L, on the 10th day I called a repairman under warranty. The day after tomorrow he will come, I’ll see what he says.
Irina
Post by Irina »
Hello everyone! I had a similar problem a year later... And I found a solution. I removed all the filters and sprayed anti-grease into the machine where the filter was, waited 15 minutes and put the machine into operation without a filter and without dishes))) AND VOILA! EVERYTHING IS WORKING!!!
Irina
Post by Irina »
Hello everyone! I had a similar problem a year later... And I found a solution. I removed all the filters and sprayed anti-grease into the machine where the filter was, waited 15 minutes and put the machine into operation without a filter and without dishes))) AND VOILA! EVERYTHING IS WORKING!!! The filters also need to be washed properly 😉
  • Automatic door opening until the end of the program
    by Marina » » in Burning
    Last post by guest
  • Opening the door with a creaking and rattling spring
    by TatyanaF » » in Midea
    Last post by Spring
  • Indesit stopped washing the dishes.
    by Euphoria » » in Indesit
    Last post by Kreutzkopf
  • All washing mode buttons stopped responding to pressing
    by Vyacheslav1111 » » in General questions about dishwashers
    Last post by Vyacheslav1111
  • The door on the electrolux esl94510lo is warped
    by Evgeniy 887 » » in Electrolux
