Brine valveGeneral questions about dishwashers
Zheka 77
My dishwasher: Ariston lsf8357
 Brine valve
Post by Zheka 77 »
Hello everybody. Briefly, I used Somat powder and a white coating began to appear, so I switched to Mr. Dez. At first the car was shiny. Then the raid intensified. By eliminating the compartment: rinse aid, powder. The ion exchanger remains. He took it off, washed it, and put it in a bowl of water and salt. The valve rang, Working. Assembled and launched. There have been no flights for three days. But the salt in the ion exchanger is dry. I’m thinking of connecting to the wires and checking whether the voltage to the valve is sold or not. The question is how much voltage to set on the tester, at what point should the valve operate? And how does it work in general?
Smoke
 Re: Brine valve
Post by Smoke »
there should be a marking on the valve. I have a Midea valve 220V. I saw the video, you can just connect a regular light bulb in parallel.
Auto-lock
 Re: Brine valve
Post by Auto-lock »
During washing, the valve opens for about 2 minutes, and only on long cycles; on short cycles you don’t have to check it
  • Bosch S2R1B red jelly in brine tank
    by albertfz » » in Bosch
    Last post by Yuri
  • Solenoid valve
    by DNS » » in Shopping Row
    Last post by DNS
  • Runs out of the valve
    by Igorbem » » in General questions about dishwashers
    Last post by Igorbem
  • Three-way valve replacement and repair
    by Walnut 84 » » in Beko
    Last post by Graphics
  • Solenoid valve connection
    by Ivan 68 » » in Electrolux
    Last post by Ivan 68
