Good afternoon.
After the welding work (welded the platinum inside the tank, the control unit was turned off), the machine began to ignore the lack of water, did not turn on the water inlet valve, and immediately started the circulation pump motor. The level sensor is working, as is the tube to it.
Please advise: what to pay attention to?
Thanks in advance,
Alexander.
Toqa Doh 57 in ⇐ Other manufacturers
