Why do you need a rinse aid?Dishwasher chemicals
Dishwashing detergents: tablets, powders, salts, flavors
Anton
Post by Anton »
I read one discussion here, it turns out everyone uses mouthwash. :%)
I’m just pouring powder. Bosch machine.
The usual condition is the burning lamps for lack of salt and rinse aid. Sometimes I add salt. Rinse aid - never. :oops: Because I don’t understand why it is needed? And everything washes well. Do you add rinse aid?
SanSanych
 Re: Why do you need a rinse aid?
Post by SanSanych »
Anton, try washing with conditioner and you will notice the difference. :wink:
Dimon
Post by Dimon »
I also never use mouthwash. it is needed to rinse dishes after washing.
but it only gives off a smell and nothing else
I don’t like the smell of perfume on my dishes, so I pour regular water in there.
and the light doesn’t light up, and the dishes are rinsed. :wink:
Sergey
Post by Sergey »
I read that rinse aid is needed to wash away detergent, and with it, water drains better from the dishes, as a result, they dry better and look cleaner and shiny.
where to pour the rinse aid.
Eat
Post by Eat »
My wife has been using only salt and Bosh dishwasher tablets for a year now and everything is fine.
Sergeyguest
Post by Sergeyguest »
I found the composition of the rinse aid to be almost the same as that of the main detergent. looks like nonsense. I would try pouring water with citric acid instead of rinse aid.
kostyanika2007
My dishwasher: Beko DSFS1530
Post by kostyanika2007 »
I’m just pouring citric acid, then I tried pouring in rinse aid. did not like. switched back to lemon.
sergeyssv82
Post by sergeyssv82 »
kostyanika2007:I’m just pouring citric acid, I tried adding rinse aid. did not like. switched back to lemon.
tell me what kind of lemon you are pouring (concentration? powder or store-bought liquid)
Tasia
Post by Tasia »
I stopped using mouthwash. I think that the dishes are covered with a thin film and that’s why they shine, why do we need extra chemicals for the body, just for beauty? This is simply luring money out of the buyer, and everything is laundered just fine.
sergeyssv82
My dishwasher: Hansa ZWM 6577 WH
I poured acid, it’s not wasted at all.. I’ve already switched to level 3 from 8..
sergeyssv82
Someone write how the rinse aid is used, how it should go down quickly or slowly?..
One fill of rinse aid lasts me about two weeks. I wash dishes twice a day. Bosch machine.
Aelita
Новичок
Post by Aelita »
If you rarely wash glassware, you can skip the rinse. I use quite a bit only when I put out glasses and bowls.
  • Extra rinse
    by Leah » » in Bosch
  • Rinse aid problems
    by Flashing » » in Other manufacturers
    Last post by Cupcake
  • Doesn't use up rinse aid!
    by aa91@bk.ru » » in Bosch
    Last post by aa91@bk.ru
  • I poured detergent instead of rinse aid into my bosch dishwasher, what should I do?
    by oyster » » in Bosch
    Last post by Kreutzkopf
  • Bosch dishwasher Rinse aid dispenser is leaking
    by right1 » » in Bosch
    Last post by right1
