Bosch SMS40D12RU error E-02Bosch
parasitic
Post by parasitic »
Good afternoon everyone.
I didn’t find a similar topic in the search, if there was one, please tell me where?
The problem is the following, the machine is a little over a year old, no longer under warranty, it worked fine, recently they started the cycle as usual, after a while Error E27 came on, "low voltage in the network"
After that, when I turn on the machine, the time of the selected dishwashing mode blinks, as expected, but when I press "start" the time stands still, no sounds , the car is simply silent, the time lights up on the display but nothing happens. I usually reset the mode, the mode was reset and that’s it, we didn’t use the machine, yesterday I decided to try to start it again, the symptoms are the same, it sits, is silent, after some time it showed error E-02 and the tap icon is on. Error e 02 stands for "NTC sensor error (temperature sensor)". Has anyone encountered this, can you advise me, is there any way to clear all errors in the machine’s memory?
Yuri
Интересующийся
Интересующийся
 Re: Bosch SMS40D12RU error E-02
Post by Yuri »
E02 - heater relay defect. It’s on the main board. Before each wash cycle, the dishwasher undergoes a short test to ensure its functionality.
  • Bosch SKS 60E12RU error e15
    by to4kaopory@yandex.ru » » in Bosch
    Last post by to everyone
  • BOSCH SPV58M50RU/17 ERROR E09
    by Vladimir » » in Bosch
    Last post by Vladimir Viktorovich
  • Bosch SMS50E02ru error E15
    by VAZ » » in Bosch
  • Error E15 Bosch machine
    by Marina » » in Bosch
