Bosch SPS53E02RU error E15Bosch
Boris Kuznetsov
Post by Boris Kuznetsov »
Aqua-Stop has worked - error E15 is on - water has entered the pan.
How to remove it from there? I would like to see what’s in there.
How can it be pulled out or do I need to disassemble the car?
I have not found adequate instructions for disassembling the car anywhere.
If you disassemble, then please order - what to remove after what.
Thank you.
Leonid
 Re: Bosch SPS53E02RU error E15
Post by Leonid »
Why look at this water? The pump did not work or broke down, so the water did not drain.
The float may be stuck. Try tilting the machine, maybe it will come out. :%)
In general, the top cover is probably removed first, then the side is unscrewed. You can find where the drain hose is connected, disconnect it and tilt the machine to drain the water into the basin.
"In general, the top cover is probably removed first" - I don’t see a single screw to unscrew it, apparently it must be removed somehow, but I don’t want to break it....
And the machine started working - apparently the moisture has dried up.
Leonid
Post by Leonid »
Guest:I don’t see a single screw to unscrew it
nWhat if you try to move it back or forward? It may be latched.
Guest:the machine is working
Congratulations! :)
Thanks for the tip with the tilt!!! the machine works again
Thanks, the advice helped too!
Thanks for the advice!
The machine is built-in, I had to put it to rest.
I wandered around in different directions. The error is gone.
The machine just turns off in the middle of the program
Sergey
Post by Sergey »
Definitely pull it out and tilt/swing a little.
I had the same problem with E15, and the water drained perfectly, but I didn’t want to fill it in (before that there seemed to be a blockage, according to my wife). Didn’t turn off at all. I pulled out the electricity. After 2 hours I turned it on again and tried to drain E15. I splashed liters of water on her. And I even tried to use a plunger to get the smell out a little, but nothing helped. I had to unscrew the side screws and pull it out. While it was halfway out, it apparently shook itself a little and threw itself off. So far so good.
Dmitry
 Re: Bosch error E:15
Post by Dmitry »
Problem with another similar Bosch dishwasher. E:15 on the screen. Flushing did not help (20 liters), the compressor works and drains everything. I turned off the power - no use.
Pull out (built-in). I tilted it forward, turned it on, another E15 cycle - and, hurray! Everything worked.
Dmitriy, congratulations! I also once had a problem like this, the advice to tilt and rock it helped. Looks like something is sticking there.
Shico
Post by Shico »
It was also E15... I shook it - it didn’t help, then I bent it to the side, something came out and it started working.... Thanks for the good advice!
Steph
Post by Steph »
What to do if the PMM is built-in? There is no way to tilt it.
Constantine
Post by Constantine »
So we bought a dishwasher, at first E15 was on, we pulled it out, shook it, turned on E15 again, shook it again, turned it on, it stopped turning on altogether, it just beeps, tell me what to do.
Thanks for the tilt, the advice helped. What is the reason for this and how can I avoid this in the future?
Valentine
Post by Valentine »
Oh, thank you very much everyone!!! When the dishwasher door slammed, part of the towel got stuck in the door and the machine leaked, grunted, groaned and E15 came on, disconnecting from the network did not help, we even waited for three days in the hope that it would dry, but no...... We thought we had to call a repairman, money pay, but read your advice and unscrewed the built-in machine, shook it and everything went out! They screwed it on again....had to align it again.....Hurray, it worked! Thanks again!
Elizabeth
Post by Elizabeth »
Guys!!
help. The BOSCH dishwasher doesn’t work
there is no click when you close it and if you turn it on with the door open, water starts pouring out of there!
what to do!???
tell meeeee
Serge
Post by Serge »
Great advice!!! I shook it in different directions and everything worked!!!
The machine is built-in, I had to remove it, but now everything is good!
I came across an E15 - the machine is built in, tilting or just moving is a problem, but I really didn’t want to wash it with my hands, I didn’t see the point in calling a technician, the Internet gave me the idea that it needed drying - I did it with my wife’s hairdryer - I unscrewed the cap of the water level sensor (I think so, what is it) put the hairdryer on the bottom, directing the air flow (at 1, i.e. not very hot) to the hole and after 10 minutes removed the hairdryer - the error disappeared, the machine is still washing!
Thank you very much for your help, your advice was very useful. The same thing happened to us, penny for penny. My daughter fixed the problem herself, it’s good that there are people like you, we didn’t have to spend money on specialists. THANK YOU!!!
For error e 15, tilting in different directions helped very effectively. Thank you.
Low bow to you Leonid and other forum members! :thanks:
I cried for a week over my dishwasher... :cry: I dried it... and it still gave me E15 and E15... no money at the master...and here you are...oooooh.... :pretty: I bent her over like a dear and she answered me... everything is fine mistress, I’m back in action ! :hello:
:horovod:
thank you kind people
Catherine
Post by Catherine »
Good afternoon!
I also have error E15, it disappears after tilting, but! At the next wash, it comes out again at the end. I called a technician from an authorized Bosch center. At first he said that it was a problem with the water pressure, he adjusted it, left (taking 2 tr for the call), and the error came out again. And now over the phone from the service they offered me to buy spare parts for 5,000 rubles - a heat exchanger and a contact. I refused because this was not mentioned during the diagnosis. Has anyone experienced replacing a heat exchanger with error E15? I don’t want to spend money without being sure it will help.
Gosha
Post by Gosha »
Ekaterina, maybe you have some kind of blockage in the water drain that does not have time to drain all the water at the end of the wash? Check just in case.
to everyone
Post by to everyone »
Guys, thank you very much for the advice. For some reason I took mine and plopped it down, everything was covered in foam. Well, I think that’s it. I spilled water on the current, E-15 burns and that’s it. I pulled it out, shook it, everything worked. THANK YOU.
Anna
Post by Anna »
Thanks a lot! You helped us out a lot :) What helped was "pull and tilt" :Bravo: :hello:
Natalya N
Post by Natalya N »
I want to join the many thanks. E15 was on and there was no water supply. The machine is built-in, they unscrewed the screws inside on the sides, took it out and tilted it. The water flowed out and the machine started working. Thanks everyone for the advice :)
Ivan
Post by Ivan »
Guys, YAY!!! That’s a working scheme!!!))) I pulled it out, shook it and everything worked)))) I was too lazy to go to the store for pills, let me think Fairy will drop a little :oops: Thanks everyone for your help :) :) :)
The hip
Post by The hip »
There are generally two reasons for water getting into the pan. The first is through the pump seal, and the second is when the water level in the car is exceeded. And excess water is poured in if the pressure sensor fails, or a small container of complex shape, screwed at the level of the tray outside the tank and connected by a tube to the pressure sensor, is clogged with dirt and grease. Water poured into the machine through a hole in the wall enters this container and compresses the air, which causes the pressure sensor to close the inlet valve and turn off the water in time. And if the valve does not close in a timely manner, water begins to flow into the pan through the pipe in the very container that compresses the air. As a rule, in this case the drain pump works, but if it does not work or cannot cope, a flood is guaranteed. The repair consists of cleaning that very container, which is theoretically possible even without disassembling the machine; it is enough to find the required hole under the filter and use available means to suck out the grease and dirt.
Larisa
Post by Larisa »
Thanks for the advice, it helped us too.
Alexei
Post by Alexei »
The tilt tip helped. Tilt to the right, to the left and voila, high technologies (sensors, etc.) work :) .
I think the reason was the pouring of new detergent into the compartment for the detergent tablet (in a large quantity (although not higher than the maximum risk).
There was an overflow on the floor and the E15 indication came up. The passport informed me that I would contact the service. After conjuring with the combination of buttons, my screen went completely dark - it became scary. If If it weren’t for the message on this forum, I would have started to disassemble it. The car stood for two days without a network and without filling up with water, figuring that the sensors should have already dried out and unlocked, but alas, it turns out there was a lot of water there.
Ivan
Post by Ivan »
Thanks for the joke with the tilt, it worked :)
Anton
Post by Anton »
Thank you very much. Bending over helped. Yesterday my wife decided to wash the “seat” for the toilet in the washing machine... As a result, I came to the conclusion that baskets with a watering can cannot be pulled out, they are flooded.
OK15
Post by OK15 »
thank you, forum members for the advice on tilting the machine, just tilt it it needs to be at a fairly large angle, about 45 degrees - I tilted it forward. Thanks also for the advice on cleaning the channel, which is located in the area of ​​the pump blades above them and slightly towards me, I felt this hole with my finger, stuck a plumber’s wire there for cleaning toilets, etc. Slowly grumbling, she entered this canal 50-70 centimeters, then ran into something. I didn’t risk pulling it back. In general, to prevent this from happening, you need to do PMM prevention once every 2 months - there is a special product like German Magic Power, it removes dirt, scale and grease.
Irina
Post by Irina »
Can you imagine I was upset, I read the advice about how to do bends and everything worked out! straightaway! otherwise I wanted to call a specialist, try
DimKo
Post by DimKo »
And I don’t have any error. The machine started washing and shut up. Now, when turned on, there is no indication at all, but the pump hums. The water in the car stays and does not go away. I would like to decide on a diagnosis.
DimKo: the pump is humming. The water in the car stays and does not go away.
Perhaps there is a blockage in the sewer? Does water drain normally from the sink?
Or is something stuck in the pump? Some kind of bone, for example? Turn off the machine from the network, take out the filter, feel with your fingers what is under the filter. Take out the trash if it’s there.
Dimko
Post by Dimko »
The sewerage is fine. The machine is old SGV 5603. Something located at the back wall is humming. When the float microphone closes, the spinner under the filter turns on. It turns without problems, there are no glass pits. The exit in the car may be blocked, but you still need to be able to get to it. Yesterday I removed the left panel - behind it there is a tank along the entire wall, all the pipes are supplied inside. Can anyone tell me which direction to take next?
Denis
Post by Denis »
And I pulled it out, tilted it forward... passed out... tilted it back... switched in... E15... to the side... switched out... switched in... E15... forward again... switched out. .. turned it on... pressed the "on/off" button... the usual "2:38" light came on. Hooray! Thanks guys! Because tomorrow is March 8th! And I am a wizard :)))
Albert
Post by Albert »
The lid for tablets does not close
Anna
Post by Anna »
How long does it take for the error to go away?
E15 came on, all the water was removed, cleaned, and when turned on, the same error occurred again.
Bloom
Post by Bloom »
Thank you very much everyone! The error was typical. The fairy plumped. After a while, it started leaking from under the machine. Error E -15 came out. I read your advice. And oh miracle! Voila it works. She broke it herself and fixed it herself. And why is this not in the instructions?????
Rabbit
Post by Rabbit »
Tilt machine works! Even I managed to do this with my little woman’s paws and the error went away! THANK YOU!!! :dancing: :dancing: :)
Valera
Post by Valera »
We were glad that we didn’t have a built-in dishwasher. Just turned off the power, tilted it forward, adjusted the hoses behind the wall, and everything turned on!!!! Thank YOU, good people!!!
Michael
Post by Michael »
I read it and couldn’t believe that a simple tilt could help. Hurray, this is really true, tilting forward 45 degrees and simultaneously draining water from the hose, everything works. Thanks a lot.
Thank you, tilting the car helped.
Vikusha
Post by Vikusha »
I also shook mine with error E 15, it helped!!!!! Hooray, it works! I also thought of adding some to the fairies, I felt sorry for the tablet on the floor of the sink.... :oops: I won’t experiment anymore. Thank you all for advice!!!
Marina
Post by Marina »
The machine is built-in, it is impossible to tilt it - you would have to unscrew it and pull it out. We decided to dry it. for a day it just stood wide open. HOORAY! the next morning the error was gone!!!
catherine
Post by catherine »
E 15 - just shake (or better yet, tilt and rock) the dishwasher: it worked great for me too (built-in, good thing the kitchen hasn’t been installed yet))
  • пмм bosch sps53e02ru
    by AND_REI » » in Bosch
    Last post by Alexei
  • Bosch SKS60E18RU error E01
    by bolt » » in Bosch
    Last post by bolt
  • Error E15 Bosch machine
    by Marina » » in Bosch
  • BOSCH SPV58M50RU/17 ERROR E09
    by Vladimir » » in Bosch
    Last post by Vladimir
    Last post by Vladimir Viktorovich
