Discount KDF 2050 W ⇐ Discount
Автор темыevgeniy.larin
Discount KDF 2050 W
About two months ago we bought and installed a machine at our dacha. I worked several times a week. Today we loaded the dishes as usual, threw in a tablet, the rinse aid and salt levels were normal. We started it for 90 minutes (we often set this program, because the dishes are usually not very dirty). At first everything was as usual, it was working and rustling there, and after about 40 minutes a signal suddenly sounded and E1 lit up. I read the instructions, it talks about pressure and blockages... Nothing from the description fits, because:
1. It has its own well and a 3 atmosphere system is installed.
2. Water comes into the house through three fine filters (the last of which is Aragon3, which essentially produces drinking water).
3. All the filters were changed a week ago after the winter season (the old ones were generally still suitable, but... tradition).
4. The supply valve is open (when trying, water fills, but then E1, squeak, drain and end).
5. There are no problems with draining (since it is individual for the machine and is heard when it gets rid of water).
I started by pulling out and washing all its internal filters - IT DID NOT HELP!
I called the officials at Korting - it DID NOT HELP (apparently their equipment shouldn’t break down on weekends, so they don’t answer the phone)
In general, as in that joke about the blonde: ". ..opened the hood, knocked on the wheels...still won’t start..."
EXPERIENCED USERS!!! TELL ME, FOR CHRIST’S SAKE, HOW TO CURE THE BABY???!!!
Re: Mapping KDF 2050W
Hello everyone!
Today I decided to try it, suddenly I “came to my senses”. I inserted the filters, turned them on... The machine suggested adding salt... I added... I loaded some dishes and turned on the 30-minute program for glass...
At first everything worked... I was happy... But after 20 minutes there was a squeak again and, this time, E4... began to drain... fell silent...
I press the power button... the machine turns off, and after a few seconds it turns on itself, shows E4 and everything is the same... And so on until I completely pulled the plug out of the socket...
I plugged the plug into the socket again and... all over again (E4, etc.). ..
No complaints about the hoses, everything is whole and working...
WHAT IS WITH THIS DU... MACHINE???!!!
Sent after 2 minutes 46 seconds:
Now we have analyzed... and the first and second errors appeared at the stages of the beginning of the rinsing cycle, it seems. ..
It was me, I just didn’t notice that I didn’t enter...Guest: ↑18 Jun 2017, 14:16 Hello everyone!
Today I decided to try it, suddenly "I came to my senses". I inserted the filters, turned them on... The machine suggested adding salt... I added... I loaded some dishes and turned on the 30-minute program for glass...
I have the same nonsense with the new Kerting 45165 machine, I would like to know how your epic ended
Hello. Yesterday I bought and installed a 2050s machine. Today, after fixing the dishes, the rinse aid lid does not open. Please help me.
scratch
- My dishwasher: Korting KDF 2050S
I’ll liven up the topic a little, because... I myself needed information on the design and repair of the Korting KDF 2050 S dishwasher. I ordered the machine through an online store with delivery from Moscow to Sevastopol, connected it myself and literally after two test runs it showed error E4 (overflow). It’s difficult to describe the emotional state when a new thing starts to work in this way, but after some thinking, I decided to disassemble it myself, because... bothering with return shipping and other nuances was not at all part of my plans. Having removed the lower pan, we saw a small puddle of water, which apparently triggered the float sensor on the pan. Having removed the sensor from its location and placed the machine on two stands, so that the whole process could be seen, I turned it on again, after which the machine began to draw water and after about 30 seconds of drawing water, error E1 triggered and immediately the machine began to drain water into the sewer and So in a circle, after starting, water is drawn in, and after 30 seconds error E1 and drained. A search for information on the Internet pointed to a possible cause of the malfunction of the water level sensor, an attempt to detect it in my machine did not lead to success, in the end I discarded all the recommendations and began to analyze how the cycle of dialing, heating, rinsing and draining actually occurs. It turned out that in this model the water level, or rather not even the level, but its approximate amount is determined by a timer and an impeller with a reed sensor at the entrance to the system. Those. the impeller should rotate when there is water, and the timer is selected in such a way that the required water level is reached at normal pressure. Not the worst solution in terms of reliability, but not the best either. I pulled out a small scarf with a reed switch sensor from under the impeller and checked it with a magnet, the reed switch did not react in any way to the presence of the magnet, after which I had to go to the radio market and get a suitable reed switch from some Soviet reed switch right on the spot from the flea dealers, the asking price was "B/ The product cost 10 rubles! I re-soldered the reed switch at home, inserted the board into place and connected the machine to the water supply and drain, everything immediately started working as normal. Just in case, I coated the motherboard on the SMD elements side with nail polish; I usually always do this on equipment where there is a possibility of water getting on the radioelements, because... even a small amount of it will be enough for the board to fail, putting everything in its proper place, I assembled the machine and I hope it will please my girls! All the best and Happy New Year 2020!
Closure
My board moved slightly away from the magnetic wheel and I also struggled for a long time until I got to this board
fiolents
- My dishwasher: KDF 2050 S
My machine is KDF 2050 S. It has stopped showing the lack of salt and rinse aid. When you turn on the machine, the absence indicators turn on and off, everything is as usual. There is no salt, no rinse aid, the indicators do not light up. The entire washing cycle runs as normal. Please tell me what could be the problem.
Kreutzkopf
On the left side, where the water approaches the fluometer, there is a box inside with a wheel and a reed switch,
