Scale gradually accumulates on household appliances that constantly interact with hot water. Dishwashers are no exception.
Problems arise due to scale deposits inside the heating element. If there is a lot of scale inside the tube, then due to the fact that scale is a thermal insulator, the heating element tube reaches the set temperature quite quickly, but the water in the dishwasher is not yet heated enough, because of this the dishwasher may not wash dishes well or give out error.
To prevent scale in the dishwasher, salt is used, but depending on the hardness of the water, after some time scale may still accumulate, in which case you need to use the product - "Antin-scale" ". Antiscale is produced by different companies and the rules of use should be read on the packaging of the product specifically purchased.
Anti-scale agent. ⇐ Flavia
Автор темыMr.Cheese
- Участник
