Can this be repaired? ⇐ Bosch
Автор темыduzer17
- My dishwasher: Bosch
Hello, forum users and masters! The following problem has arisen - machine Bosch (if I need a model, I’ll get into the paperwork) I started not finishing the cycle to the end, stopping 30-40 minutes before the end. I found a method on the forum with pouring boiling water (3-4 times), turning off the water and turning on the machine - it seemed to help, it worked. Organized descaling. After a few cycles, it began to stop at 115-120 minutes, turning off the network (not the button) helped, the process resumed and reached the end. But after another 3-4 cycles the machine stopped - can you only hear the relay clicking? and that’s it, nothing else helps. I checked the inlet hose, it was slightly clogged, I cleaned it, but there was no effect. Is there any way to treat this or is the cost of the issue such that it’s easier to throw it away?
