What is there to sin about? ⇐ Indesit
akhmadeev. 1984
Pmm indesit DFP 27B+96 Z washes but does not rinse dishes, the washing, drying and end indicators are on. The pause, salt, and rinse aid indicators are flashing. When you turn on the machine, the pump first turns on, then the main pump turns on, then the pump turns on again and water begins to flow and the washing cycle starts. After its completion, the machine drains the water and displays the error described above, the water heats up, the pan is dry.
