Sent after 9 minutes 33 seconds:
I have an Ariston Li-675 DUO, with an incomprehensible "sore":
When filling it starts beeping..... It beeps three times and goes into error.
Sometimes it works fine. Sometimes it beeps three times, but then continues to work.
Of course, I checked the pressure switch! I also checked the circulation sensor (with a reed switch). The heating element is also normal.
What’s strange is that it starts beeping after 35 seconds. sometimes a little more. Sometimes it works fine.
In short, there is a strange malfunction of some kind. And it was in the process of collecting water....
I bought a control board and replaced it with a new one - it didn’t help ((((
[size=85] [color=green]Sent after 9 minutes 33 seconds:[/color][/size] I have an Ariston Li-675 DUO, with an incomprehensible "sore": When filling it starts beeping..... It beeps three times and goes into error. Sometimes it works fine. Sometimes it beeps three times, but then continues to work. Of course, I checked the pressure switch! I also checked the circulation sensor (with a reed switch). The heating element is also normal. What’s strange is that it starts beeping after 35 seconds. sometimes a little more. Sometimes it works fine. In short, there is a strange malfunction of some kind. And it was in the process of collecting water.... I bought a control board and replaced it with a new one - it didn’t help ((((
