Resetting the PMM program Weisgauff tdw 4106Other manufacturers
Barbarians
My dishwasher: Weissgauff tdw 4106
Post by Barbarians »
Has anyone encountered a PMM control failure? The washing cycle times are disrupted, the water temperature does not rise above 35-40 degrees. I took it to the service center under warranty, it stayed there for 3 days, they returned it and they said that the device was fully operational. After this, the PMM worked normally for 2 weeks, and here it is again. I suspect that the service reset the PMM program with some key combination and after that everything worked.
A characteristic feature is that when starting the PMM, after drawing water, the washing mode (pump) does not turn on immediately, but after 4-5 short periods by 0.5 -1 sec. inclusions.
  • The dishes are wet after the end of the program
    by Guest » » in Bosch
    Last post by Lentetta
  • Program crash
    by Augustina » » in Indesit
    Last post by Augustina
  • The dishwasher does not remember the last program
    by mgorshkov » » in Bosch
    Last post by mgorshkov
  • Hyundai 480 do I need to restart the program after E1
    by Yuri B. » » in Other manufacturers
    Last post by Yuri B.
  • does not respond to program selection
    by behind » » in Chrono
    Last post by behind
