The husband has his hands full. But he still can’t figure out what’s leaking. It’s leaking into the pan under the car itself. The only option is to remove the pan, put it on four stools and see what’s leaking. I checked all the connections, all the seals, covered everything with gasket sealant just in case case, even the float, hoses, chambers. Suspects that the engine seals may be leaking. Could it be them? He can fix it, the main thing is to understand what’s wrong
It may leak from under the connection of the housing with the glass on which all the engines are attached. You need to remove the protective cover from the front and right side and look at it during the washing process at a very high temperature.
The Indesit D61 machine suddenly started overflowing water yesterday. :( :( :(
What could be the problem? Maybe the level sensor is covered? Where is it located? I machine I looked it up, but I can’t find it.
The dishwasher is leaking from the bottom left near the back wall.
Can anyone tell me if there are two pipes leaking or, more correctly, two pipes of the stove which on the side of the connection there is a rubber seal and that’s it, it squeezes out the water when you fill it up, but WADA goes inside the dishwasher
Video of the problem:
66xgqD1jvHk n d-MUvJnahsw
What could it be problem?
Looks like the bottom seal needs replacing?
Sealing it with sealant helped for a while, but recently it started leaking again. I decided to try to cover it up again - it didn’t work at all. I waited more than 24 hours and turned it on - it immediately started leaking. What could be the problem? Why doesn’t it even stick to silicone anymore?
The best solution is to find a similar one seal from Ariston (namely Ariston, not Hotpoint) you can...
Hello everyone! The Wellton WDW t5 dishwasher leaks, but not always. More precisely, sometimes. The first time I thought it was because they spilled a lot of detergent. The last time was recently, there was definitely enough detergent. I opened it up, there was rust on the bottom, I looked at everything - I blame this thing in the photo. This is some kind of float with switches, it looks like it...
Built-in dishwasher (5 years). Previously, the aqua-stop worked once every couple of months, but after drying it worked normally again. The aqua-stop hasn’t worked for half a year, but the dishwasher has started leaking. I can’t figure out why, every 3-5 washes a puddle appears to the left of the car, soapy, dirty, not very salty (no more than a glass). The puddle appears quickly, i.e. not in...
If you spent the winter with water, look for a crack in the salt tank; If you spilled salt and did not turn on the rinse according to the instructions, then the salt could gnaw a hole in the washing chamber. Does the leakage sensor work? Check the bottom of the door seal for deformation.
